Jan 26, 2026 10:05:37 PM UTCmodified on Jan 26, 2026 10:23:52 PM UTC
I´ve installed the new version.
After I disable "Backlight -> keep always turned on" in Configuration -> Android Wear the heartbeat will only be measured for some minutes by Smartwatch and transferred from Smartwatch to the Smartphone (heart symbols: no colour). When you move your smartwatch (which enables display) the heartbeat will start to be measured again.
I used Run.GPS Trainer UV Full + Wear OS version before and this worked with the same hardware although ""Backlight -> keep always turned on" was switched off. I also checked the permissions - all as mentioned in the YT video.
Any idea?
Hardware:
Smartphone: Google Pixel 9 Pro
Smartwatch: Google Watch 4
You can:
- Remote control your Run.GPS phone app
- Autonomously record activities on the watch (and sync to your phone afterwards)
- Record your heart rate
- Display basic data on a tile
If you own a Pixel Watch, a Galaxy Watch or any other Wear OS based watch, please give it a try. Feedback welcome!
Latest release addresses battery life and other issues - this is always a big problem on those small watches.
For comparison: When I run
- Run.GPS with tracking turned on (including heart rate and pedometer)
- Spotify streaming music over LTE, using a Bluetooth headset
at the same time, my Pixel Watch 3 (45 mm) will last about 3 1/2 h, which is quite okay.
Improvements:
- less power consumption
- bug fixes
Please use only this version, as the other versions ("Lite", "Full", "TRIAL") are discontinued. It's free :-)
Note: You cannot install the PRO edition together with other versions on one device, because the included Facebook provider collides so Android won't allow you to install different versions of Run.GPS. Don't forget to upload or backup your activities before uninstalling the other versions.
