GPS-Sport ForenRun.GPS SoftwareUploading a training session to the server
qdabean 29.08.2007 09:26:15 UTC
Thanks for that Robert. Not too sure why strange numeric value happened as I did nothing out of the ordinary although the weather was bleak and I was getting some pretty odd readings from my GPS as you can perhaps see from my training session (no I wasn't running drunk!).
Also just want to say what outstanding service you guys give. Quick to respond to queries, fantastic software with plenty of updates. Keep up the great work!
robert 28.08.2007 08:24:35 UTC
Yesterdays training recording which had the problem can now be found at http://www.gps-sport.net/detail.jsp?trainingID=3778.
robert 28.08.2007 08:23:22 UTC
Okay here's the result: there was some problem at the end of the trainining recording which caused the latitude/longitude values to be much too high. This may happen when the device gets shut down unexpectedly due to an empty battery, for example. All training objects with out of range latitude / longitude values are now filtered out so this won't happen again.
Best regards
robert 28.08.2007 07:24:39 UTC
Hi qdabean
it's better to speak English here since it can be understood by nearly everybody.
Your problem with upload is confirmed, the message is:
>>> reading training by user qdabean
ERROR:
SQLException in WriteTraining: '293342031167756000000000000000000000000000000000000000000000000000000000.000000000' (Zahl) liegt außerhalb des Gültigkeitsbereichs für die numerische Darstellung (maximale Genauigkeit = 38).
Zahl (beginnend mit '12661857935024600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000') ist zu lang.
The message means that there's a numeric value in your training recording that is too great to be stored in our database ... :-) But how did it get there? We'll have a closer look at your data soon.
Regards
qdabean 28.08.2007 01:11:25 UTC
Hi there
I completed a training and uploaded the session but it still has not appeared on the webpage. It's been 24hrs. I have uploaded again multiple times since then but still no luck. I am using UV and have uploaded session fine in the past and no settings have been changed.
Any ideas?
Sorry if this has already been discussed in German on this forum (sorry I don't speak German).
