GPS-Sport ForenRun.GPS Softwareusername enters only numeriek
robynpooky 05.12.2009 13:11:29 UTC geändert am 05.12.2009 13:13:16 UTC
Temporary solution
Go to \Storage Card\My Documents\Run.GPS\users\uv-user\user.xml
You can edit this file and replace uv-user in the password field with your Run.GPS! user ID and just below that entry, enter your password.
<?xml version="1.0" encoding="UTF-8" ?>
- <user>
<userName>USERNAME</userName>
<password>PASSWORD</password>
<gpsiesUserName>uv-user</gpsiesUserName>
<gpsiesPassword />
<osmUserName>uv-user</osmUserName>
<osmPassword />
<crossingwaysUserName>uv-user</crossingwaysUserName>
<crossingwaysPassword />
<password>PASSWORD</password> should be on one line
do this if you have accounts at the other websites as listed in the XML file
then save the file.
This does not fix the data entry problem from the keypad or keyboard however.
robynpooky 05.12.2009 12:52:19 UTC
Pantech C820 with same problem
I am having the same problem with my Pantech C820. Is there a solution?
hballeis 07.11.2009 19:59:44 UTC
HTC 730 Backspace problem
I made it already several times without sucess to turn on or off the "Alphanumeric Keyboard" setting in Main Menu > Configuration > General Settings
Tom 07.11.2009 18:14:25 UTC
Maybe it helps to turn on or off the "Alphanumeric Keyboard" setting in Main Menu > Configuration > General Settings?
hballeis 07.11.2009 17:48:07 UTC
HTC 730 backspace problem
2.3.3 Build 1701 does not work too
Tom 07.11.2009 16:42:30 UTC
This is weird! Did you try the very latest build (2.3.3 build 1701 on www.rungps.net)?
hballeis 07.11.2009 16:16:27 UTC
HTC 730
left Softkey for backspace does not work! no key for backspace works!
tobinz 21.09.2009 03:08:20 UTC
Backspace
Try the left soft-key for backspace.
hballeis 20.09.2009 20:59:39 UTC
HTC S730
my HTC S730 has no possibility to correct an enter by backspace. At HTC S710 the backspace works.
Do not understand why! What mobile phone works without problems?
tobinz 12.09.2009 19:40:12 UTC
There are two keyboard related settings, hardware keyboard, etc. There is another forum post that says to have both checked, well that fails miserably. I don't have it in front of me, but I checked the first setting and unchecked the second. This allowed me to enter letters using the number pad. Less than ideal, but at least it worked. I don't know why these guys don't use the standard in put method specified by the phone.
