you can find it in your root directory. If I understood, the UV-Version uses only one user uv-user.
The older version use the user you choosed in you configuration ... if you did not change it, it is called default.
You can find all your trainings in /MyDocuments/Run.GPS/users/default/trainingsYYYYMM (year and month)
