GPS-Sport ForenRun.GPS SoftwareRecorder screen blank (Just grey squares...)
clarre 27.10.2009 17:01:03 UTC
Sure, will do!
admin 27.10.2009 16:58:03 UTC
Thanks for the information. Please tell us if this happens again. At the moment it's hard to track down that bug because we could not reproduce it yet.
clarre 27.10.2009 15:12:48 UTC
Yes, I did.
Nothing happend... I have now re-done it manualy. So it is not the end of the world. Just wanted to report the bug...
admin 27.10.2009 15:10:48 UTC
Did you try using the "reset to default" function? Hold the stylus pressed on one of the diplays and then execute the reset function. This resets all displays and the layout to default.
paulgosden 27.10.2009 12:46:35 UTC
Mine did the Same
Hi there,
Mine did the same,I've never had it happen before, all squares went grey and had to manually put them back by holding the blank tabs and adding the info back. It only happened on the recorder screen. Running on a xperia x1 with the latest build 1661. must be something with the latest build perhaps?
Paul
clarre 27.10.2009 10:28:03 UTC
My Recorder screen is blank. The squares that normaly show differnet data is just grey.
Today when I started the app on my HTC Touch HD, it first showed the normal Recorder screen but after a few seconds, all the squares went grey. That is still the case after restarting the app and telephone several times. I have also reinstalled the latest release of the app. Still nothing!!! The other screens work fine. Any idea, anyone?
Best regards
C-H
