GPS-Sport ForenRun.GPS SoftwareHelp with versions
admin 28.12.2009 13:20:04 UTC
Could you please give me some information. Right now I have no clue because it works for other users and we could no reproduce that error on our devices.
- What version of Windows Mobile?
- What version of .NET Compact Framework? Did you try installing the .NET CF 3.5 (free for download from MS)?
- What device?
Cyb 23.12.2009 17:29:46 UTC
Same problem here. As suggested by jfam, it seems that version 233 bild 1655 is working fine, but latest version don't.
jfam 17.11.2009 14:17:00 UTC
No, i search and nothing, i try the registry and nothing.
It´s a nightmare, all other versions works and stop in 1655.
Never mind i stay in 1655. Thank you
admin 17.11.2009 10:20:25 UTC
This is very annoying. We never got that error before.
The error means (according Microsoft):
"The exception that is thrown when a program contains invalid Microsoft intermediate language (MSIL) or metadata. Generally this indicates a bug in the compiler that generated the program."
But it works for all other users, so there cannot be a general problem with the compiled code. The only thing I can think of is that there's parts of an old version somewhere. Maybe in the main memory? /Program Files/Run.GPS...?
jfam 16.11.2009 21:17:55 UTC
Don´t run
Hello
Thanks for your rapid answer admin, none of the solution works, run.gps contnues with the message of error.
I delete the configuration.xml and maps.xml and user.xml, none.
What happens please tell me, or i stay forever in 233 version 1655 like a tree in end of life. eheheh
admin 16.11.2009 13:08:33 UTC
Seems like your installation is corrupt and some components of the old version 1655 cannot be replaced.
Try the following:
- uninstall Run.GPS
- restart the device
- remove all remaining program components from the device, folder /sdcard/Program Files/Run.GPS or similar (but don't delete the data files from folder /sdcard/My Documents/Run.GPS)
- reinstall Run.GPS 2.3.4
If that does not help, you may also try deleting the file /sdcard/My Documents/Run.GPS/users/uv-user/user.xml but you will have to re-enter some settings.
jfam 14.11.2009 13:15:21 UTC
After 233 buiid 1655...
Can you tell me please why after the version 233 build 1655, the all versions include the last one 234 wont run.
Is the same message in all versions, so i stay in 233 bild 1655. Thank you
Iniciate and them the message says:
Run,Gps.TrainerUV.exe
InvalidProgramException
em cs.ad(int32 A_0, int32 A_1, int32 A_2, int32 A_3)
em fj.an()
em dj.as(Graphics int32 A_0, int32 A_1, int32 A_2)
em de..ctor()
em e7.a()
