GPS-Sport ForenRun.GPS HardwareZephyr HxM - BATTERY
picha 11.01.2010 15:40:12 UTC geändert am 11.01.2010 15:40:46 UTC
It was problem of my phone ,now OK
Sorry ,now i configurated the Hxm to automatically start when i started the program .Do you know if it`s necesary to close the connection before close the program or when i close the program automatically close the connection?
admin 15.12.2009 10:37:09 UTC
This is not normal! Our experience is that using Bluetooth does not significantly decrease battery lifetime. GPS normally uses much more energiy than Bluetooth.
Maybe you could try to place the device in another spot on your body because sometimes the body shields the signals from the antenna, which causes the Bluetooth module to send at full power. I did make that experience with a A2DP headset.
Maybe you'll also have to replace your battery.
picha 15.12.2009 09:22:17 UTC
FAST LOST OF BATTERY
Hi ,I bought the Zephyr HxM and my first impression is very good.But my battery ,the diamond battery, was short-lived only half an hour. Are there some problem with my configuration? or this is normal .
Normaly my battery life is adout one hour or two ,all connected (GPS,Radio normal bluetooth) .Are there some configuration to adjust to improve the battery life using the Hxm?
THANKS
picha 15.12.2009 09:19:57 UTC
lost the battery
THANKS
