GPS-Sport ForenRun.GPS HardwareDroid & HxM
admin 06.04.2010 16:04:58 UTC
Jabra BT3030 + Zephyr HxM works flawlessly with several smart phones.
orodiger 03.04.2010 20:06:53 UTC geändert am 03.04.2010 20:07:00 UTC
HTC HD2 Bluetooth headset and HxM heartrate monitor not working well together
I also have problems using both a Altec Lansing Backbeat 903 bluetooth headset and the Zephyr HxM heartrate belt. I got a device.exe crash or RunGPS stopping to collect data as well as the sound coming across a bit strange. I can confirm the bluetooth as the source of the issue as when I use the wired headset via the 3.5mm jack everything sounds fine and no crashing or locking occured.
There is sill a ongoing problem with the HxM reading the heartrate wrongly, but the cadence and speed seems to be OK.
avionics 12.02.2010 14:21:16 UTC
System seems to be working but, I am having issues using BT headset and HxM at the same time. I need to determine if it is a start-up sequence issue or, if you cannot use both at the same time. Will post update once I have spent some time troubleshooting this issue.
