GPS-Sport ForenRun.GPS SoftwareProblem Connection HRM HXM bluetooth windows phone 6.5
samos20 02.05.2010 23:18:24 UTC
Thanks it s now working
It s now working fine. I didn't use the right code.
Thanks for your answers.
Sam
santoshrane 29.04.2010 12:03:15 UTC
I hope you have your Zephyr connected to your chest when you are trying to do it?
1: Stap the belt and attach your Zephyr to the belt.
2; try withcode 1234. I have it and it works fine. Aso if its right out of the box, you may want to charge it and then try. let me know pal.
jenskohrs 27.04.2010 11:49:26 UTC
hello
you must enter the code #1234# for HrM / HxM bluetoothdeviceand select serialport com2
it works ve4ry fine.
cfarrell 27.04.2010 11:48:13 UTC
Try 1234 as code
According to the Zephyr HxM spec, the correct code is 1234
samos20 26.04.2010 22:45:17 UTC
Problems of Connections HRM HXM bluetooth on my windows phone 6.5
I bought the Zephyr HXM HRM and tried to connect with my windows phone 6.5 ( HTC touch pro2). Do you have the right way to connect my bluetooth devices. I don't understand, it's not working. When i connect the é device by bluetooth, the phone ask me a code. I tried 0000, but it's notworking. I tried the port 1, 2 ..... but it's not working. Do you have the right procedure? Thanks in advance.
