GPS-Sport ForenRun.GPS GeneralActivity level explanation
mprogl 02.05.2010 12:20:56 UTC
Hi all,
the red number means the difference to the month before. So if you actually have for example 6,6 (-0,8) you hade an activity level of 5,8 one month before.
brotsje 30.04.2010 18:21:33 UTC
Re: Activity Level Explained
Hello rbalansay
I am not sure that I understand what you mean.
Are you saying that when your level for example is 10(-3.0), your level till now is 10, but that the level of the last training is 3.0 below your average level of 10?
I don't think it works like that because today I had a faster training then general with the same distance, but my level and specialy the red number in brackets is exact the same as yesterday, 6.6 (-0.7)
Brotsje
rbalansay 29.04.2010 16:55:54 UTC
The way I analyzed it is if the level is like 10(-3.0), your current level should be at around 7.0 with average
progression this means you move up so fast in the rankings. if it is like 11.0(+.9) your ideal position should
have been 11.9 this means you were so active then you stopped exercising or not input your workout in Run
Gps.
brotsje 29.04.2010 12:56:08 UTC
Hello Wobu2000
I am not sure about that. For example yesterday my activity level was 6,6 (-0,8). 6,6 shows already dat I am 40% from the next level 7, but this (-0,8) means minus 80%?. Or is it actual 6,62 (80% from 6,6 to 6,7. But that makes it to precise.
It is a little bit confusing. Actually 6,6 is already enough information.
Maybe the person who implemented this number in the webpage can explane?
wobu2000 29.04.2010 12:19:30 UTC
Hello Brotsje,
i think the red number stands for the way to go before reaching the next activitylevel ( next animal )
brotsje 29.04.2010 09:44:45 UTC
New with the activity rating is that your activity level not only shows a picture but also level numbers. The first number is clear, but what is the meaning of the second number, the red number between brackets.
Can someone explain this?
