GPS-Sport ForenRun.GPS GeneralProbleme GPS Empfang Samsung B7610
the_doctor2k 13.12.2010 15:32:34 UTC geändert am 13.12.2010 15:33:22 UTC
EDIT: didnt read all posts, i see that my settins are same as haller
Hi there,
i have a samsung B7610 and it works fine in run gps.
Settings are
Untick windows managed (it NOT windows managed)
COM port COM7
baud rate 4800
untick use .NET COM port (ie do NOT use .net port)
Haller 15.07.2010 13:20:19 UTC geändert am 15.07.2010 13:20:43 UTC
Yihaa !
In a last desperate effort to try and make the GPS work - I spent hours reading about GPS and Samsung Omnia series - Apparently the problem isnt only related tho the antenna - Many have tried changing the comport settings and baud rate - Choosing COM 9 + a higher baud rate seemed succesful ?
I ended up with Com 7 (programport), COM 9 (hardwareport) and baudrate 4800... Then i tried google maps, Rung gps and route 66 navigation on the phone - Position fix within 10 to 20 seconds max - Anytime , anywhere :-)
I ran 25 km. using the internal GPS and run gps (dop 24) - 100% stable with perfect speed calculation etc.
Then 25 km on my MTB - 100% stable with perfect speed calculation etc.
- Then i drove 40 km using route 66 - 100% stable with perfect speed calculation etc.
I have used my Samsung B7610 without external gps for 6 days now and havent had a single problem with the internal gps ????
I migth start missing the feeling of being captain Kirk when RunGps insisted on, that I just had beeen beamed to Sweeden or that i was running with the speed of a SR71A Blackbird ???
Haller 28.06.2010 00:20:48 UTC
I bought a B7610 just for running (gps, maps, music ect...) But the GPS did'nt seem to work properly ?
- Afterwards i learned, that it is a known problem to many samsung mobiles - especially B7610....
So I bought an external GPS (bluetooth) / It works perfect... / i never found any other solution..
Paule_rennt 26.05.2010 13:31:57 UTC
Hello Bartek,
i use the same settings. Which setting did you have at the other points (speed, DOP etc....)?
Thanks for your help.
Paule
jabol20 23.05.2010 12:22:11 UTC geändert am 23.05.2010 12:22:36 UTC
Hello
I have Omnia B7610 and I don't have such problems. Maybe sometimes on very bad weather.
My setting are:
In Run.GPS - windows managed on
In windows GPs settings on hardware tab - COM9 & baud rate 4800
Maybe You have wrong baud rate set?
Bartek
Paule_rennt 20.05.2010 18:02:53 UTC
ich suche immer noch..
Habe ständige Ausfälle des GPS und das trotz freien Feldes.
Bin für jeden Hinweis dankbar.
Paule_rennt 06.05.2010 13:29:12 UTC
welche Einstellungen habt ihr beim Omnia Pro B7610 vorgenommen, damit rungps optimal läuft? Ich habe ständig GPS Aussetzer und auch wenn ich Empfang habe, dann immer nur Empfangsqualität schwach. So macht es natürlich nicht wirklich Spaß, da ständig Pausen angezeigt werden, obwohl ich keine gemacht habe. Hierbei ist es auch egal, ob ich in einem Waldstück laufe oder unter freien Himmel bin.'
Danke für Eure Hilfe.
der Paule
