After some issues, I now decide to share my configuration in order to compare it to yours and finally decide which is the most appropriate one, after fine tuning.
I think, this could be some kind of recommended (and then set as default) parameters by RunGPS Team when installing the application.
These are mine, especially for GPS Settings:
- Manage by windows. "NO" (unchecked)
-- Port COM4
-- Thoughput 2400 bauds
- auto-connection at start-up. "YES" (checked)
- Lissage:
-- Speed: 35s;
-- Altitude: 15s
- Maximal DOP: 8,0
- Speed: use GPS values. "NO"
- Automatic correcting altitude. "NO"
-- Manual value: 0m
I'm using an HTC HD2, in France, with French language menu. I hope I have properlly translated all the fields.
I use Run.GPS for Mountainbike. My actual release is 2.3.6c build 1961.
Please specify your device if different from HTC HD2, and your version od Run.GPS.
