GPS-Sport ForenRun.GPS GeneralRunGPS on HTC Desire?
gebgebee 13.10.2010 23:23:19 UTC
@dlorde: you are correct. I'm used to do the same now and everything's fine. By the way, I was wrong in my previous post, I need to activate GPS first. The only difference is that i'm using the earphone to get information and don't need to unlock the screen during the run.
dlorde 02.10.2010 14:10:12 UTC
@gebgebee - on my Desire (running Android 2.2), I activate GPS, start RunGPS, press 'Go', then switch the screen off (tap top button on Desire). Everything continues working while the screen is off. To check distance, position, or stop & upload data, tap on top button again, drag down screen unlock bar, and RunGPS is still there.
gebgebee 17.08.2010 23:53:12 UTC
I don't even need to activate GPS first on my desire. It works pretty well but I need to find the way to lock the screen because the phone is in my pocket and there are a lot of unintented request on the screen during the training.
KINULINA 15.06.2010 12:10:53 UTC
works!
i have no problems on the Htc desire with run gps.
you should activate gps on htc before you start rungps.
elaget 19.05.2010 12:19:02 UTC
The app is not able to get GPS data
Anybody using Desire successfully? Other similar programs are working fine but RunGPS is not able to start the GPS and retrieve any GPS data. Also there seem to be some glitches in the UI with the big 800x480 screen..
