GPS-Sport ForenRun.GPS SoftwareUnable to find app in Android market (V1.6)
Hauffe 27.09.2010 12:39:44 UTC
Habe dasselbe Problem mit meinem Xperia X10.
Im Marktet kann er die Version nicht finden und leider funktioniert auch die unter Download zur Verfügung gestellte .apk Datei nicht!
drakomir 19.07.2010 18:57:19 UTC
I have the same problem with LG GT540 and Android 1.6
I can't find this version in Market.
user_187113436 19.07.2010 14:25:40 UTC
Hi
I have the same problem with a x10 mini in Denmark. Can't find it in the marked.
Isn't possible to put the download on the run.gps page - together with the download for 2.0?
ivonobel 14.07.2010 15:24:08 UTC
I think I found the origin of my problem:
I've been reading through a number of posts about people being unable to find apps after a firmware update and that Google need to make the sure firmware on the phone is approved first
There is seems to be a problem with the SE Xperia X10 with the latest firmware of R2BA023
[URL]http://www.google.com/support/forum/p/Android+Market/thread?tid=125126d6ba9800b5&hl=en[/URL]
ivonobel 14.07.2010 14:52:24 UTC geändert am 14.07.2010 14:57:42 UTC
Thanks for the quick reply. However I'm still unable to find the app. See my screenshot.
It's a Dutch version. Translation: There are no hits in Android market for the search terms [b]run.gps[b]. Suggestions: make sure the words are spelled correctly, try different search etrms, try less specific search terms.
Is there a download link to 1.6 version of the app?
Tom 14.07.2010 13:46:42 UTC
We now have a special version for Android 1.6 on the Android Market.
We had to split it up into different versions because Android Market detects the capabilities of your phone and then decides if you can see a certain version.
Android 1.6: does not support Bluetooth Serial Port Profile
Android 2.0 and higher: does support Bluetooth Serial Port Profile
You should be able to see the Android 1.6 version in Android market! I can see it when I use a 1.6 device (T-Mobile G1).
Use "Run.GPS" as search term.
ivonobel 14.07.2010 13:30:16 UTC
I'm unable to find updates for RUN.GPS in the market.
I live in the Netherlands and i'm using Sony Ericsson Xperia X10 (android version 1.6)
Could someone give me the link for 1.6 version of the app?
Downloading from the website gives me error on install.
John
