GPS-Sport ForenGPS-Sport GeneralUsing <script ...> in Sportlers homepage
admin 10.01.2012 14:57:21 UTC
This should also work correctly now.
No, there is no alignment command yet.
bolos 10.01.2012 09:02:09 UTC geändert am 10.01.2012 09:04:00 UTC
Thank you for the quick response. Now <script> is working
Rearding newline
If I enter
save the page and reopen the page for editing I get
And the real page shows a \ between the lines.
If I add therafter the missing \ then everything is okay.
BTW. Exists a command to align a line ? (left,right,center)
admin 09.01.2012 15:12:09 UTC
We have checked this and found out that the problem occurred because Google changed its gadget code from
<script src="http://www.gmodules.com
to
<script src="//www.gmodules.com
so our recognition did not work anymore. We have now changed it.
I also tested the newline issue, but for me \\ works.
bolos 07.01.2012 17:15:23 UTC
Hello,
I try to add gadget code on my homepage but as a result I only see the code 1:1 on my homepage and not the gadget itself.
Also I try \\ for a newline, but only if I double it "\\\\" the new line is "visible".
Can anyone help?
thanks, bolos
