GPS-Sport ForenRun.GPS Wishlist / IdeasWhat Run.GPS should not change for the future releases
admin 05.03.2012 15:06:23 UTC
Thanks for your good suggestions, which will be discussed for upcoming releases.
Regarding altitude information: that would be possible, but of course only through an online service.
Kardaman 04.03.2012 14:01:07 UTC
Hello Run.GPS
Because I have to use other Sport Apps at the moment (ANT+!) I want to thank you for your feature rich software. Things you should not change for future releases are:
- Do not introduce muting of music during voice feedback of Run.GPS. It makes more sense to give the user a direct link to the TTS engine setup to control the volume of the voice, so it could always be a little bit louder than the music.
- Do not introduce, that we need GPS reception before we can start to record a training. Its "better" not to have the first 100m recorded than to wait 30sec before you can start the training.
- Its very important, that ALL configurations (Voice feedback, Intervals, map settings...) are changable during a training recording. Do not change this!
- The opportunity to go on with an allready started training is great, don't change it!
- Do not change anything to the Intervall training configuration. Its by far the most powerful out there.
(+please add the opportunity to config each interval individual with km or time)
And now some wishes for the next UI:
- Slide left and right to the next View (Recorder, Map, Intervall...) and the opportunity to change the order of the different screens like the start screens on most android phones. On Samsung you can change the order per drag and drop, thats nice.
- gesture control would be great: different gestures for Start/Stop of training, Intervall On/off, Music Mute/unmute, Voice feedback On/off and so on.
- pinch to zoom
- long press on the map for adding placemarks, coordinates and so on
- and height information out of the map data for a point in the map. Is that possible? would be nice to see on the map, which height difference exists between two point of the map.
So much for now. For the UI I have thousand other ideas................
