GPS-Sport ForenRun.GPS GeneralRatlas maps on WP8
johnny_knoe 30.07.2013 18:47:10 UTC
Would be great!
admin786557 29.07.2013 14:52:39 UTC
OK I can confirm your observations. Your device (and many other WP8 devices) does not have a SD card folder :-(
Stupid enough, WP8 does not allow apps to access the "Windows Phone" folder, so it is no solution to put the file there.
WP8 offers only a very restricted access for apps to the file system.
The only solution for this (as suggested by a Chinese Run.GPS user - thanks) would be to make it possible to download Run.GPS Atlasses through the Gps-Sport Download cart. We'll do work in that direction and see if we can offer this solution soon.
johnny_knoe 29.07.2013 09:07:09 UTC geändert am 29.07.2013 09:08:11 UTC
This doesn't work for me. When i connect my Lumia 920, the windows explorer shows the following:
-"My Phone"
---Phone
-----Documents
-----Music
-----Pictures
-----Rintones
-----Videos
So i created a folder calles Run.GPS and placed my .ratlas file there. Looks like this:
-"My Phone"
---Phone
-----Run.GPS
But it's not possible to select the ratlas-Map inside the app. I also tried to place the .ratlas file directly in the root folder ("Phone") and inside the "Documents" folder and even in a sub-directory ("Documents\Run.GPS"). No luck as well.
admin786557 23.07.2013 09:18:36 UTC
If you connect the device to your PC using an USB cable you should see two volumes in File Explorer. One of which is usually called "Phone" and the other "SD card" (although the SD card volume is also built-in memory).
Josey.McWales 22.07.2013 12:57:26 UTC
Release 2.7.1 and Lumia 920
Release 2.7.1 is now available for Windows Phone 8. It has support for "Run.GPS Atlas" (.ratlas) files
Manual says that ratlas files should be copied on a "Run.GPS" folder on the SD card.
The Nokia Lumia 920 doesn't have an SD card slot. Is it possible to use ratlas files on the Nokia Lumia 920 ?
Josey.McWales 17.03.2013 11:47:21 UTC
Using Ratlas maps on WP8
Is there any way to use Ratlas maps on Windows Phone 8 ? I'm using a Nokia Lumia 920 and I cannot find any way to copy the .ratlas files to the folder suggested in the user manual.
