GPS-Sport ForenRun.GPS GeneralHRM HxM & Run.GPS Trainer UV Pro Trial
admin786557 03.06.2013 09:09:06 UTC
The logic behind the Bluetooth HxM connection is as follows:
1) User clicks "Connect" button
2) Run.GPS reads the heart rate monitor type from its configuration
3) Run.GPS searches for paired Bluetooth devices that match the name "Zephyr HxM"
4) If one is found, Run.GPS establishes the Bluetooth connection
5) Run.GPS loads the corresponding heart rate monitor driver to interpret the heart rate data
If there is no pause after trying to connect, this usually means that there is either no paired device with the matching name or Bluetooth is not available.
droptail 01.06.2013 05:37:21 UTC geändert am 01.06.2013 05:38:30 UTC
As stated below, it must be paired to work with my other apps, Edmondo Sports Tracker reads HxM, (but not GPS), and Zephyr Heart Monitor works sometimes.
Of coarse I wear it (water on strap and skin) when trying to have it read.
I will say all this is all new to me, Android phone (GS3 clone), apps, HRM, GPS, and am having alot of trouble.
As I said before, a message saying "Please wait" flashes very quickly when trying to connect, in about 1/10 second, and then disappears.
Why doesn't it search for a little while?
admin786557 31.05.2013 20:41:50 UTC
This should actually work.
Did you pair it in Android Settings? Do you wear it while you try to connect?
droptail 31.05.2013 17:37:05 UTC
yes. type: HxM HRM.
when I try and connect HRM, I immediately get Not Connected eror:
failed to connect HRM. Pls try different settings.
It doesn't spend any time searching for the signal.
admin786557 31.05.2013 08:04:56 UTC
Yes it is supported by Run.GPS Trainer PRO TRIAL.
Did you set the heart rate monitor type in Configuration >> Heart Rate Monitor?
droptail 31.05.2013 07:12:25 UTC
To be clear, it is supported by the Pro Trial version?
Don't know why this app won't read HxM, but my others will.
I'm running Google™ Android™ 4.1.
thanks
admin786557 29.05.2013 15:44:50 UTC
Yes, it is supported by Run.GPS. But it depends on your operating system if you can use the HxM.
Overview of Compatible Heart Rate Monitors
Windows Phone 8: Zephyr HxM
Windows Mobile: Polar Bluetooth WearLink+, Zephyr HxM
Google™ Android™: Polar Bluetooth WearLink+, Zephyr HxM, for ANT+ capable smartphones (e.g. Sony Xperia series) also ANT+ based heart rate monitors
Apple™ iOS (only iPhone 4S and iPhone 5!): all Bluetooth Low Energy (Bluetooth Smart) compatible heart rate monitors, e.g. Polar H7
droptail 26.05.2013 08:19:36 UTC
HRM
Can't get heart rate using HxM & Run.GPS Trainer UV Pro Trial.
Is it supported?
