GPS-Sport ForenRun.GPS Wishlist / IdeasTemp Backlight - Hardware button
Tom 25.03.2008 12:34:59 UTC
Hi Phil
it's the right "-" key with which you usually open the "Contacts" in Windows Mobile. You have to check the "use center key for start/stop" setting to use the backlight function.
Best regards
bf2mad 24.03.2008 21:35:13 UTC
I have installed 2.2.0, any idea what the "right function key" is on a XDA MiniS?
With RunGPS locked and the "backlight off" setting checked I have pressed every button on the phone but the backlight does not come on?
Any ideas?
Phil
robert 12.03.2008 15:29:24 UTC
Okay it's on schedule for the 2.2.0 release.
<http://www.rungps.net/wiki/ChangeHistoryUVEN>
bf2mad 11.03.2008 23:24:34 UTC
I would be interested in this too.
I leave my phone running run.gps in my back pack with the back light turned off and have problems tring to unlock my phone as I can not see the icon very well with the back light off.
Maybe if the Phone \ PDA is in locked mode with the back light off if you tap the screen the back light comes on for around 5 seconds giving you enough time to read your stats on the screen or unlock the device?
SlimboyFat 05.02.2008 21:15:42 UTC
How about an option that we can set one of the hardware buttons to turn on the backlight even when in Locked mode.
If this was to give say 5 or 10 seconds it would....
a/ Easily let you see your progress.
b/ Save you from having to find the lock icon.
c/ Allow you to see the lock item to make it easier to unlock.
but due to the small amount of time the backlight would stay on it should not cause any problems if it is accidentally pressed.
