GPS-Sport ForenGPS-Sport GeneralGPX speed units?
admin786557 18.03.2014 10:36:26 UTC
Right! Thanks for checking this.
The bug is corrected now on GPS-Sport.net and the unit is correctly set to m/s.
eltsov.denis 18.03.2014 06:21:23 UTC
Now I am shore that if I download GPX file from for example http://www.gps-sport.net/trainings/running_1338412
Actions -> Download GPX
<SPEED> units are km/h
And if I export GPX from Run.GPS application <SPEED> units are m/s
I make a test on a car.
This is part of file export from Run.GPS
<?xml version="1.0" encoding="UTF-8"?><gpx version="1.1" creator="Run.GPS Trainer UV" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" schemaLocation="http://www.topografix.com/GPX/1/1/gpx.xsd" xmlns="http://www.topografix.com/GPX/1/1"><metadata><name>unnamed</name><desc/><link href="http://www.rungps.net"><text>Run.GPS by eSymetric GmbH</text></link></metadata><trk><name>unnamed</name><trkseg><trkpt lon="30.427173400" lat="59.823627430"><ele>36.166666667</ele><time>2014-03-18T08:24:16.200Z</time><speed>0.000000000</speed></trkpt><trkpt lon="30.428237570" lat="59.823878920"><ele>36.166666667</ele><time>2014-03-18T08:24:18.899Z</time><speed>0.000000000</speed></trkpt><trkpt lon="30.428608690" lat="59.823964620"><ele>36.166666667</ele><time>2014-03-18T08:24:19.901Z</time><speed>0.000000000</speed></trkpt><trkpt lon="30.429695450" lat="59.824216620"><ele>36.166666667</ele><time>2014-03-18T08:24:22.913Z</time><speed>0.000000000</speed></trkpt><trkpt lon="30.431136930" lat="59.824544570"><ele>36.166666667</ele><time>2014-03-18T08:24:26.937Z</time><speed>0.000000000</speed></trkpt><trkpt lon="30.432536010" lat="59.824907630"><ele>36.166666667</ele&
eltsov.denis 12.03.2014 09:52:14 UTC geändert am 12.03.2014 09:53:11 UTC
Thank you.
But it's a little bit strange for me because of my last activity.
If you can look at GPX file of my track 10.03.2014 12:05:00 PM, 5.56 km, you will see that for a long time I run faster then 10 meters per second
I am really proud of it, but can't believe such a good result :)
And all so when I try "training simulator" it show me speed in about 10km/h and it's seems to be ok, because it was orienteering.
admin786557 12.03.2014 09:35:17 UTC
<SPEED>
Optional in: <wpt> <rtept> <trkpt>
Units: meters per second
<speed>4.23</speed>
Instantaneous speed at the point.
It is the same as the speed on the portal, which is computed using GPS data by Run.GPS (using a modified continuuos Douglas-Peucker algorithm).
eltsov.denis 11.03.2014 12:26:28 UTC geändert am 11.03.2014 13:03:28 UTC
Tell me please in what units I'v got speed when I download GPX file. Is it m/s or km/h?
And one more question how it calculated, direct from GPS or the same as speed on portal?
Best regards Denis
