GPS-Sport ForenRun.GPS Wishlist / IdeasExport GPX to Dropbox
kielstra 20.08.2015 09:27:17 UTC
Thanks for the clarification.
admin 20.08.2015 09:23:34 UTC
If you resume and upload again, it will overwrite the already uploaded training. In the case of Dropbox, the file is simply overwritten. In the cases of Smashrun and Google Fit, the activity is identified by an ID and is also overwritten, so no duplicated will be produced.
kielstra 19.08.2015 19:13:15 UTC
Thanks, it's working.
So, everytime i press the pause button on my watch my workout will auto upload?
But what happens when i resume my workout (press play button on my watch) Will it upload a second workout?
admin 18.08.2015 17:03:45 UTC
Did you try manually uploading to these services (Online Services >> Sync to portal)? In each case, a browser window should pop up asking you to enter credentials.
If that doesn't work, please post your device type / version and operating system version here wo we can check it.
kielstra 17.08.2015 19:21:29 UTC
My run does auto upload to run.gps site. but no luck wit Dropbox, Fit and Smashrun (all the services are checked)
Am i doing something wrong?
admin 17.08.2015 16:50:41 UTC
Yes. The pause button on the wear device has the same function as the stop button on the phone.
kielstra 17.08.2015 14:20:54 UTC
Will Autosync work if i press the pause button on my Android wear device? (no Stop button present on watch)
admin 23.07.2015 07:56:40 UTC
Yes that should be possible.
Currently we're working on a syncing module for Google Fit and the new release will also support auto-sync (training is uploaded each time you press the stop button).
Auto-sync will be possible for gps-sport.net and for Smashrun.com. And also would be for Dropbox, I guess.
gamsbok 23.07.2015 07:55:56 UTC geändert am 23.07.2015 07:56:15 UTC
wodge80 22.07.2015 12:28:37 UTC geändert am 22.07.2015 12:31:28 UTC
I agree!
I agree! I too have been asking for activity syncing with other apps and services such as Tapiriik. http://www.gps-sport.net/forums/thread/2871-0/
Syncing to Dropbox would be a quick compromise if we can select the folder to upload the activity data to.
Tapiriik has been storing activity in the Apps/Tapiriik folder in dropbox as TCX files
At an absolute minimum, I would be happy if the Run.GPS app could automatically save my activity in TCX format somewhere on my Android device so I can set up an autosync with Dropbox with a thirdparty app such as foldersync.
