GPS-Sport ForenRun.GPS SoftwareMissing buttons/elements in GUI
Tom 06.03.2008 16:41:56 UTC
Hi upschippi,
we have noticed that sometimes transparent images are not loaded correctly by Windows Mobile - i.e. the icons sometimes have white backgrounds though they should be - transparent. Maybe your issue is related to this.
Some concept which might help:
- free more main memory
- move the application from a storage card to the main memory, if you have installed it on the storage card (maybe the memory access on the storage card is too slow)
Best regards
upschippi 28.02.2008 02:05:10 UTC
Blank fields instead of buttons or elements
Hello to the community, this is my first post.
I'm using this fine soft for several weeks and all works very well, instead of a problem with the GUI. Some of the buttons and/or icons are missing in the GUI an instad of them there are blank fields.
For example, I'm missing the buttons for zoomimg (in and out) or sometimes the settings button in the map view, but this behavior changes at every application start and other elements on different sites are gone.
I de installed and re installed the .NET CF 3.5 (and other versions) but it was the same issue as before.
What may be the cause for this issue?
T-Mobile Vario III / HTC Kaiser
WM 6.0
.NET CF 3.5
