Currently we have the display dimmed after the timout period but not turned off if the "Keep background light" option is on. This is because constantly using the display light at full brightness drains the battery too fast for most users.
However we'll consider integrating a "keep background light at full brightness" option for the next release.
Yes thats annoying. I have made a tasker profile that checks if run.gps is running and sets the display timeout to several hours and sets it back if run.gps is closed. But thats a workaround solution not for everyone and if you offer a button to avoid display timeout it should work. And like Sonntagsradler said: Other apps do manage this, too.
Hello,
I have the option "Keep background light" ON.
But the display darkens down to about 50% after the normal Display-Timeout time.
All other (gps/navigation) apps with similar option keep the display full on. Only Run.GPS does it not. Therefore I have to touch the display very often :-(
