GPS-Sport ForenRun.GPS SoftwareEdit Training
robert 13.03.2008 13:45:44 UTC
Ok ... done :-)
sring 13.03.2008 02:16:06 UTC
Thanks Robert,
I'm sorry but the second training link in the previous post had a correct date/time value but incorrect duration value: http://www.gps-sport.net/trainings/Ingraham+w_Mission+Bay+return_12319
Could you please update this training to:
date/time: March 3rd, 2008 6:30pm
duration: 0.1:06:54
I found the 'add activity' function.
Thank you for you help!
robert 12.03.2008 14:22:49 UTC
I changed the date of the two trainings. You cannot change it yourself.
You can find the 'add activity' function in the 'Training Log' below 'add manual'.
sring 11.03.2008 22:06:19 UTC
So is there a way to update the training below to the correct date of March 5th? Or should I just delete and 'add manual' and update the manual training? What do you recommend?
The date/time attribute is set to Mar 3rd but I ran on Mar 5th: http://www.gps-sport.net/trainings/Jetty+with+Beach+Return_12460
sring 11.03.2008 21:22:56 UTC
OK, Thank you for the explanation.
I have UV Pro but I cannot locate the 'add activity' feature. Will you please tell me where 'add activity' is located?
admin 10.03.2008 08:42:41 UTC
I understand your point. What you say is not a bug, because normally Run.GPS will not behave like this. If you load a navigation route and start the training two days later, the training date/time will be that of the actual training.
I think the problem is that you used the 'add manual' function. This should be used only if you want to enter a training session for which you didn't take Run.GPS (e.g. swimming). If you add a manual training, then load this training and push the start button, the training time will be that of the originally entered 'manual training'.
To avoid this in the future, we'll modify Run.GPS so it's not possible to load and continue manual training sessions.
About Example 2: same as above, you shouldn't use 'add manual' and then add data to this training through the GPS. If you have Run.GPS Trainer UV Pro, you can use 'add activity' if you want to plan a training session.
sring 07.03.2008 23:59:27 UTC
I'll try and explain it differently since I didn't get the answer I was looking for:
Example 1: The issue I have is that the date/time attribute is actually the *date route downloaded* when I think the data/time should show the date last edited. In my case the date of my run is set to Mar. 3rd when I actually completed the run on Mar 5th. I want to fix this so that Mar 5th appears in the date/time attribute but I don't see a way to edit this attribute see links:
The Calender does not show when I actually ran the route:
http://www.gps-sport.net/users/sring
Example 2: I created a route IN THE RUN.GPS CLIENT by opening the Run.GPS client application and selecting Training Log & Plan>add manual. I then entered in the attributes including duration of 1.5 hours, but I ended up not running that far.
robert 07.03.2008 07:49:14 UTC
Example 1: The date/time attribute is not incorrect - if you run the route on Wednesday it is correct to set date/time of that run to Wednesday. The creation date of the route is still Monday. If you follow the route exactly in your run, the route and the training will be connected as for instance here:
http://www.gps-sport.net/routes/3mi+Reynolda_1188
Example 2: It's not possible to create a route on the Run.GPS client. You can either create a training plan or add a manual training entry - the latter of which is the case, I think. You don't need to create a manual training entry if you want to run. Just push the start button.
sring 06.03.2008 17:50:33 UTC
Edit Training
I'm interested to learn how to edit all attributes of my training after I have created the training on the PDA. I would also like to be able to make edits to all attributes of my training after uploading to the Run.GPS server.
Example 1: I created a route on the Run.GPS server and downloaded it on Monday to my PDA. Then I didn't run the route until Wednesday. So now the date/time attribute is Mar. 3, 2008 and is incorrect.
Example 2: I created a route on Run.GPS client and entered a duration of 1.5 hours. I then only ran 1hr but the duration is now 2.5 hours which is incorrect.
What steps do I take to correct the errors in the examples above?
