GPS-Sport ForenRun.GPS GeneralMonthly and Yearly Performance do not load data
pdrunning 22.12.2015 17:18:09 UTC
ok, so thats the reason
admin 22.12.2015 14:28:19 UTC
They are just simple HTML fragments loaded through Ajax. But, yes, for Internet Explorer using Ajax requires an ActiveX object:
http://www.javascriptkit.com/dhtmltutors/ajaxgetpost.shtml
Example:
function ajaxPost(url, data, callback)
var passData = data;
var AJAX = null;
if (window.XMLHttpRequest)
AJAX=new XMLHttpRequest();
else
AJAX=new ActiveXObject("Microsoft.XMLHTTP");
if (AJAX==null)
return false
else
AJAX.open("POST", url, true);
AJAX.setRequestHeader("Content-type", "application/x-www-form-urlencoded");
AJAX.onreadystatechange = function()
if (AJAX.readyState==4 || AJAX.readyState=="complete")
callback(AJAX.responseText, AJAX.status);
AJAX.send(passData);
return true;
pdrunning 22.12.2015 14:12:38 UTC
it seems that active-x filtering is blocking these tables
so those tables are active-x components?
admin 17.12.2015 11:34:37 UTC
I've checked IE11 on Windows 10 and Windows 7 and in both cases, these views do load correctly. Perhaps the server was momentarily overloaded. Both views are loaded after the main page is loaded.
Another possible explanation would be that there's some sort of security tool or ad cleaner installed on your IE11 that keeps additional content from loading.
pdrunning 15.12.2015 12:05:41 UTC
seems like both views have problems, they are stuck in loading status: 'loading ....':
- windows 10
- IE11 problem as discribed
- Edge it works fine
