Survey: ANYBODY ELSE OUT THERE USING THE FITBIT ARIA?
Yes it is being considered. We'd do it the same way as with the Withings body scale: Retrieving body weight updates would be handled through gps-sport.net (not through the app). You'd have to connect your Fitbit account as it is being done with the Withings account on this page: http://www.gps-sport.net/dialogs/bodyWeight/settings.jsp
I buy mine at FNAC and tested and only work with the phone app, and the software not always work, so they give my money back and then I buy the fitbit one, that work as I expect. But if you say that work fine with you, great.
Really? I have a Withings Body Scale at home and it directly synchronizes through WiFi (no need for an app). It's also stated on Amazon for the current products that they support both Bluetooth and WiFi:
Withings Body Scale, needs un app to send data to the internet ( I tested ), Fitbit Aria does that without un app ( I have one), fitbit scale talks direct to the fitbit account.
I prefere to use the fitbit Aria scale and also would like to have Run.Gps to sync body weight from fitbit.
Please allow Run.GPS to sync body weight from Fitbit Aria scales
Please allow Run.GPS to sync body weight from Fitbit Aria scales.
https://www.fitbit.com/au/aria
The Fitbit aria syncs body weight and body fat % to the fitbit.com account. Please design an api to allow the body weight and body fat % from fitbit sync to the gps-sport.net account as well.
