GPS-Sport ForenRun.GPS Softwarealtitude bug
recneps 18.03.2008 14:04:27 UTC
Related to total ascent/descent?
Could this issue be at all related to another issue posted here:
http://www.gps-sport.net/forums/thread/262-0/Total%20ascent%20descent%20not%20working
Still having an intermittent problem with totaling ascent/descent. Altitude is logging fine.
Thanks,
recneps
mozanne 18.03.2008 11:06:39 UTC
speed buffer has an influence on altitude!
Well I made an interesting test: I moved speed buffer from 5 to 15 sec... and my altitude problem was solved!
I do not think that GPS signal strength is the explanation, especially because speed etc.. was working fine. It is in the soft that we must find the soution!
can you tell me more about the influence of buffer on altitude calculation ??
robert 17.03.2008 16:55:03 UTC
That's probably because the signal gets weaker when you move, especially when you hold it in your hands or put it in a bag while moving. It also depends pretty much on the current satellite constellation, so it might be better or worse next time. There's nothing one can do but trying to place the device in a spot where the signal is not blocked.
mozanne 16.03.2008 16:09:36 UTC
Altitude is not updated when I move
On my HTC smartphone RUNGPS works pretty well except for altitude... when I move.
When I swich on the GPS, altitude is identified with a reasonable precision.
BUT
As show on my track: http://www.gps-sport.net/trainings/parapente_13294
Altitude is updated only when I stop moving. As soon as I move the altitude is not updated anymore.
how can I fix that?
