GPS-Sport ForenRun.GPS SoftwareBug in Training Plan
Tom 17.03.2008 12:48:19 UTC geändert am 17.03.2008 15:03:58 UTC
Hi Krille
thanks a lot for the bug report. The bug you mention will be fixed in release 2.2.0 coming out in about a week.
Both downloading via download cart and direct synchronization of training plans will also work only with the new release 2.2.0. If you want to use a training plan from the module here in the portal, you can copy the .tml file into /My Documents/Run.GPS/trainingplans/ using ActiveSync. This is the only possible way for now but soon the new release will appear which will make training plan handling more convenient.
Change history: http://www.rungps.net/wiki/ChangeHistoryUVEN
/Tom
Krille 16.03.2008 19:44:48 UTC
For the record, I use 2.1.2 build 809.
I just bought this wonderful software and was excited to try out the training plan feature on the website. I was then going to download it to my pda and use it for my weekly runs.
When i had created my training plan online, i added it to my download cart, but i did not pay attention to the message: requires Run.GPS Trainer UV Pro 2.2.0 which is right beneath the cart button... :-/
So, i used the Download cart-function on my pda, and thought that my plan was downloading (which it was not) and then opened the Training Log & Plan inside Run.GPS.
I clicked manage training plan and then load since i thought it was downloaded.
Now a message appeared: Load training plan?. Click Yes and a new screen appear, which is blank because I have no plans (i gather my saved and/or downloaded plans should be here if they existed).
On this screen, if you click OK without selecting a plan, the program hangs.
Maybe not a big issue, but I thought you might want to know about it..:-)
/Krille
