Tom,
Thanks for the suggestion - I suspected that the functionality would require some added complexity.
Regarding the second GPS-Sport login - that login would then have to be changed on the phone before each upload, right? I already have a hard time remembering to change sports before using the application, so that would probably be too much user complexity for me :->
Well this would make the application a bit complicated to use :-) Maybe later.
You could
- create a second user on GPS-sport.net with same password and switch between the 2
- use sport "cycling" when mountainbiking with your daughter (caloric burn would be a bit different)
I generally use Run.GPS for cycling and mountainbiking (some walking). Within each, I try to include rides with my 8yr old daughter, which makes for a very rewarding experience. When all of my mountainbiking rides are averaged together (as on GPS-Sport), my average speed is considerably lower since the recreational rides are averaged in with the faster solo and adult group rides. In this way, the average value has little meaning to me.
If you could provide the ability to 'clone' each sport and add a meaningful suffix to the end (IE mountainbiking-fun and mountainbiking-training), then assumably these would be classified as different sports and be averaged separately. To keep it simple, all 'cloned' sports would have the same caloric burn rate as the parent sport.
