GPS-Sport ForenRun.GPS SoftwareKeyboard Lock
user_175058162 09.05.2008 15:59:48 UTC
I understand now why ! To do it may use more memory using RAPI dll or something like that....
So now I use a DeviceLock for WM 6, just the screen is not refresh but my PDA is in my pocket or in my neoprene belt ;)...so not a matter !
It's just in case I'll put my PDA visible on my bike...but not now especially since my rear wheel have crossed a tree branch...which kill my derailleur :(
Tom 09.05.2008 12:37:29 UTC
That's right, the phone keys are not disabled by the lock function. This is intended because when a phone call comes in you would have no chance to turn off the lock so you couldn't accept that phone call. Some workaround would be to access the phone API and disable the lock when a call comes in, but we haven't tested that yet ...
Slogfester 29.04.2008 18:49:05 UTC
I used to have the 3600, now have the 3650. I have found on both it is easier to return to the today screen and use the key lock which HTC supply.
user_175058162 29.04.2008 17:46:50 UTC geändert am 29.04.2008 17:49:27 UTC
I'm not sure but if it's a bug from Run.GPS or my device or a choice but I can't lock completely my device.
When I lock Run.GPS by pressing the image of the padlock of Run, it lock the screen, the laterals keys, the pad keys (I choose to lock the keyboard too in settings and not to use the Dpad to start recording).
But it doesn't lock the green and red keys and so if I press one I can make a call, return to the today screen....
Is there a way to lock theses keys too, is it a problem of my device or do you plan to not lock theses keys ?
My PDA is an HTC P3600 on WM6.1.
Thanks in advance.
The keys are red circle on this picture :
