GPS-Sport ForenRun.GPS SoftwareInaccurate altitude
user_175058162 13.06.2008 09:29:53 UTC
Since my latest test (2.2.5 build 1027) everything is ok for the altitude correction !
Thank you for this fix !
PS : cause of my doctor (always listen them...) I had to stop sports for 3 weeks, so maybe it was ok with an older release but now it work !
user_175058162 14.05.2008 09:24:21 UTC
Hi Robert,
I'll wait for this new release to test this feature.
I've near 40/50 meters more than real, not a big deal but where I live it's big ;)
So I'll test the new release and if not perfect ;) for me I'll try to make a manual config with the COM port enabled by WM6.1 for my embedded GPS.
Thank's a lot.
Antoine
robert 13.05.2008 15:56:07 UTC
Hi toniolol
well your altitude doesn't seem to be that wrong either ...
GPS altitude is mostly pretty inaccurate and there's nothing much you can do about it.
Regarding manual altitude correction: until now this field was relevant only for COM port based (NMEA) GPS connections. But I guess the manual correction also makes sense for managed GPS sometimes, so we decided to enable that. It will be available in today's service release 2.2.3 build >= 980 (released tonight).
user_175058162 10.05.2008 20:12:25 UTC
since I use Run.GPS I've problem with altitude.
You can see it on my all trainnings.
I've tried many things in setting, the automatic correction and the manual.
The last attenp was with manual -120 and it make nothing...
Am I alone with this problem ?
My PDA is HTC P3600, GPS embedded, on WM6.1.
Thanks in advance
