GPS-Sport ForenRun.GPS SoftwareBattery crash...where are my datas ?
Tom 20.06.2008 19:21:19 UTC
This shouldn't have happened with release 2.2.5. At the moment I have no explanation :-( With release 2.2.5, the track data is constantly streamed to a file. The stream is flushed very often.
I'll try to do the same and see if I face the same problem ...
user_175058162 17.06.2008 16:36:56 UTC
Hi Tom,
Thanks for your help, I can restore one part of my datas.
Do you know why can I only save 2.87Km on 5Km ?
The 2.13Km lost were in memory ?
http://www.gps-sport.net/trainings/crash_26531
Thanks !
Tom 17.06.2008 11:48:37 UTC
Hi Toniolol
thanks for testing. This is because the app has no chance to write the "training.quk" and the "training.xml" summary files when it crashes. This means that the values are not displayed in the training log but all the data is present - nothing is lost.
A workaround is to load the training and then start and stop the training so all required files are written. GPS should be disconnected for this so no additional data is added.
Probably we'll solve this issue later by writing a "lock" file so Run.GPS can recognize it crashed when it is restarted.
Best regards
user_175058162 17.06.2008 10:34:42 UTC geändert am 17.06.2008 10:37:04 UTC
Hi Tom,
Yesterday I make a new attempt and Run.GPS loose all my datas.
So I record 5 km in my car and at 5.0 I made a soft reset.
When I start again Run, it said me 0.2 km done and when I tried to send to portal or see data it tell me that an error occurred but if I want to see it I must have a special Framework cab, maybe the debug cab from Microsoft.
And today I open again Run and it said me 0km but if I upload it in memory it says 2.87 Km....
I post you the ScreenShots and maybe you need datas.
http://toniolol.free.fr/e107_files/downloads/RG.zip
Regards
[1]Infos
[2]main screen
Tom 25.05.2008 11:44:47 UTC
Hi toniolol
normally it helps to load that training from the training log with GPS disconnected (so that no new data is added) and then start and immediately stop the training. Upon stopping, all training data is stored anew.
Regards
user_175058162 21.05.2008 15:15:33 UTC
I write this help request for a French user who is not very familiar with English so maybe it can make few time to answer to your questions....
So this morning he make a training and while this training is battery crash, how could he found datas which were saved when his PDA worked ?
Thanks in advance.
