GPS-Sport ForenRun.GPS SoftwareLaps time !
2ninja 23.06.2008 17:46:29 UTC
thank for your anwser but are you sure of that ?
I had ever export data but i forget how i do this !
My version is Trainer UV 2.2.2 :-)
Tom 23.06.2008 16:43:52 UTC
For that, you need a PRO licence. Go to training log, then select a training recording and select Details > export as CSV.
2ninja 21.06.2008 23:14:15 UTC
my data !
hi,
how i can export my data to csv file ?
thx
2ninja 25.05.2008 22:34:33 UTC
Good what it is necessary to do and what I do not have do is to define the finishing line!
I charged thus my recording and fixed on the screen “map” a reference mark like “finishing line/departure” at the place of the finishing line.
Then by changing screen for “Turns”, it does not recompute and I have always one turn!
They are lines 47/48 of the handbook!
2ninja 25.05.2008 21:04:51 UTC
Good evening,
thank you for the answer.
since I did not define the line at the time of my course motor bike, can I take again my recording and to specify or is the line?
Thank you
Tom 25.05.2008 12:25:25 UTC
Hi 2ninja,
you have to define the target line as navigation goal for that:
1) go to the target line
2) double click your current position on the map
3) select "navigate to position"
You have to activate the "new lap when target is crossed" in the General Settings.
At very high speeds it might happen that a lap is not detected.
Best regards
2ninja 22.05.2008 22:01:25 UTC
Time Laps no detect !
Hello,
I used run.gps on a circuit of motor bike and I thus have make several times the same course.
I believed that run.gps detected the turns when one passed to the same place several times! Isn't this the case?
Can I obtain times of each turns despite everything?
Thank you.
