GPS-Sport ForenRun.GPS HardwareHTC Touch Diamond - no altitude!
Erste Seite<Seite1von3>Letzte Seite
user_1788104370 28.08.2008 10:05:19 UTC geändert am 28.08.2008 10:06:08 UTC
Hard Reset
Yes hard reset will usyally help. I had weeks ago problems with GPS and hard reset solved that.
CaptainCalamity 28.08.2008 09:54:54 UTC
Thanks Spaca
I have just HARD RESET my diamond, re-installed Run.GPS, setup my RUN.GPS as you speicified and now GPS instantly finds satellites, even sitting indoors.
I read on another forum that a hard reset will sort your GPS out if it gets into problems, only problem with that is I have to re-install everything now.
But now I am getting more accurate readings and altitude in Run.GPS.
Thanks again Spaca for you help
user_1788104370 28.08.2008 09:16:37 UTC geändert am 28.08.2008 09:41:25 UTC
If your Diamond have older ROM then try baudrate 19200. I have no problems with COM4 and 57600 baudrate.
Example:
http://www.gps-sport.net/trainings/rollerblading_38286
I noticed that Windows managed GPS finds satellites faster than manually configured. So, you have to wait little longer when use manual configuration...
CaptainCalamity 28.08.2008 08:46:17 UTC
As I said in my thread I have tried everything including this, when I uncheck windows managed in the GPS setup on Run.GPS, then set manually to COM4 and the baudrates suggested, the GPS never connects, just sits searching for ever.
Then if I switch back to windows managed, instant GPS location, yet still no altitude...
user_1788104370 28.08.2008 08:31:52 UTC geändert am 28.08.2008 08:34:41 UTC
Psybadeck and CaptainCalamity, please read whole thread and you can find solution!
(Uncheck windows managed GPS, then use COM4 and baudrates 4800 or 57600)
Psybadeck 28.08.2008 08:26:36 UTC
Altitude
Same for my Diamond, everything works fine, except the altitude. Is there any hint, or solution?
CaptainCalamity 19.08.2008 18:39:01 UTC geändert am 21.08.2008 14:26:19 UTC
Please is there no answer to the altitude problem,
CaptainCalamity 19.08.2008 18:38:55 UTC
I have just started using my HTC Diamond with RunGPS, the latest version 2.2.6
Applications loads perfectly quick, finds GPS fix almost instantly and records fine except it won't record Altitude at all.
See my latest run
Distance: 8.41 km (5.23 mi)
Date/Time: 19-Aug-2008 15:58:00
Duration: 0.01:11:58
Active Time: 0.00:58:24
Total Average Speed: 7.01 km/h (4.36 mph)
Active Average Speed: 8.64 km/h (5.37 mph)
Calories: 880 kcal
Min Altitude: 0 m (0 ft)
Max Altitude: 0 m (0 ft)
Ascent: 0 m (0 ft)
Descent: 0 m (0 ft)
Juanan 31.07.2008 20:12:51 UTC
No aparece la altitud en la HTC Diamond
Tengo una HTC Diamond y no consigo que aparezca la altitu, hay alguna solución.
Gracias.
________________________________________________________________________
I have a HTC Diamond and can not bring up the altitu, there is some solution.
Thank you.
user_1788104370 24.07.2008 16:17:35 UTC
GPS not connecting when application is started - FIXED
Problem "GPS not connecting when application is started" fixed with new RunGPS_UV_EN_build_1158!
