GPS-Sport ForenRun.GPS SoftwareSpeed and distance are not recorded althrough there is GPS connection.
tkaub 09.07.2008 14:45:06 UTC
Thanks you so much Robert
I really appreciate your help, cause now i can record maps and see the speed and everything is working fine on my
phone....
Have a nice day.
Cheers.
T.K.
robert 09.07.2008 09:33:23 UTC
This might be one of the following problems:
- you activated the "GPS ID Bug Fix" option in GPS configuration - it must be deactivated for your device (this happened to many users)
- your GPS is not set up correctly (in this case, please follow the description in the manual) - but this is rather unlikely if you see the satellites on the GPS status screen
tkaub 06.07.2008 12:30:45 UTC
Speed, distance, map, nothing is working althgouht there is GPS connection
Hello Guys,
I have downloaded Run GPS, on my HTC P4350, I have an external GPS which I use for Tomtom and other
applications. My current status:
Run GPS is still trial,
the GPS is connection and I have a good signal,
When I press "Start" and run for a distance, the timer starts but no distance, speed, calories, nothing is recorded.
I tried to use the map and record my GPS coordinats but also nothing is recorded.
Please may you help me in this issue, cause I like this software alot but it is not working at all...
THanks in advance
Regards
T.K.
