GPS-Sport ForenRun.GPS HardwareGPS connection problem with HTC Diamond?
user_1788104370 01.08.2008 09:25:56 UTC
No problems with new buid
Sorry delay, but I was in rollerblading accident. :( None broken bones so I'm back soon...
GPS works great with new buid. Weird, but still I think that baudrate 57600 gives better satellite connection than 4800. :o
Juanan 31.07.2008 23:37:40 UTC
Gacias, ya lo he conseguido.
_____________________________
Thank you, and what he achieved.
Tom 31.07.2008 20:20:03 UTC
Yes there is.
1) Go to GPS settings
2) turn off "Windows managed" GPS
3) use instead COM4 at a baud rate of 4800
Note: you must use the very latest release for this (2.2.6 build >= 1160)
Juanan 31.07.2008 20:13:29 UTC
No aparece la altitud en la HTC Diamond
Tengo una HTC Diamond y no consigo que aparezca la altitu, hay alguna solución.
Gracias.
________________________________________________________________________
I have a HTC Diamond and can not bring up the altitu, there is some solution.
Thank you.
user_1788104370 29.07.2008 18:27:34 UTC
Great work
Thank you! I will test and report back tomorrow!
Tom 29.07.2008 18:05:34 UTC
We want this to be absolutely stable ...
So here's a new test release that gives the GPS even more time to get connected:
http://downloads.rungps.net/Setup_RunGPS_UV_EN_build_1159.exe
Maybe you could also try reducing your baud rate to 4800 - seems to work for other users and for Run.GPS it doesn't matter which baud rate you use.
user_1788104370 29.07.2008 10:44:41 UTC geändert am 29.07.2008 10:48:06 UTC
Maybe it isn't Run.GPS related problem
I think that isn't actually only Run.GPS related problem. I have read fistfull of threads from forum.xda-developers.com where Diamond users reports that some times they can't wake up GPS. Solution is to do "a kickstart" with different program like GPStest or HTC GPS tool. After kickstart GPS works normally. I could think that I had same problem at yesterday! Maybe these programs will help you to solve problem at last!
GPStest http://gps.pdatopsoft.com/PocketPC/GPS-Test
HTC GPS tool http://forum.xda-developers.com/showthread.php?t=360477
More info (exemple thread) http://forum.xda-developers.com/showthread.php?t=412400&highlight=GPSTEST
Tom 28.07.2008 21:41:22 UTC
That's bad. Anybody else who still has the problem?
(HTC Diamond does not connect GPS on startup when configured to COM4@19200)
user_1788104370 28.07.2008 19:18:00 UTC geändert am 28.07.2008 19:18:36 UTC
GPS not connecting when application is started -problem is back
Sometimes GPS still not connecting when application is started! Situation is now better but sometimes I still have to start GPS manually (sometimes have to do it couple times before it starts).
andi22 24.07.2008 18:08:05 UTC
2.2.6 Build 1158 funktioniert jetzt einwandfrei auf COM4@4800.
Keine Problem, GPS direkt beim Start. Thanks
