GPS-Sport ForenRun.GPS Hardwarehelp entering license information on Samsung Blackjack II
kpowell10 13.08.2008 16:04:16 UTC
That worked - thank you! Now I just need to get on the bike :)
robert 13.08.2008 08:19:31 UTC
Oh I'm sorry I forgot to mention that. It must be named 'licenceuv.dat'.
kpowell10 12.08.2008 16:25:20 UTC
Correct, the Blackjack II does not have a touch screen. What does the license file need to be named for rungps to see it?
robert 12.08.2008 10:35:25 UTC
The Blackjack II does not have a touch screen, right?
If your device is not configured to use an alphanumeric keyboard (Configuration > General Settings), you may be able to switch the characters like on a standard cell phone with the numeric keys. By pressing the Fn + 1 keys multiple times you'll get a hyphen.
If that doesn't help, please try the following:
1) on your PC, create a text file containing the licence code in the first line, without hyphens, in upper case letters, e.g. "AAAABBBBCCCCDDDD"
2) copy this file to your Blackjack, directory /SD-Card/My Documents/Run.GPS/ (the name of the SD-Card may vary)
3) start Run.GPS - the licence should be there
kpowell10 11.08.2008 19:17:18 UTC
Hi - when I try to enter the license information on my Blackjack II, the function key ("Fn") doesn't work, so I'm unable to enter numbers or hyphens. My function key does work in every other application. How can I work around this? Thanks
