GPS-Sport ForenRun.GPS GeneralHi, My Run.GPS has loaded the maps but I cannot see them.
Tom 02.09.2008 13:43:53 UTC
Hi Berni
you may send one .jpg and the corresponding .xml file to info@esymetric.de so we can check it.
Regards
berni29 29.08.2008 07:38:17 UTC geändert am 29.08.2008 07:39:30 UTC
Hi Tom, thanks for the reply, the ID bug fix is not enabled, and the instructions on how to load maps was followed to the letter.........I have tried the map related to my current location with a good fix, but comes up blank.
Thanks again
Berni
Tom 28.08.2008 15:29:04 UTC
Hi Berni
- are your GPS coordinates correct? did you manage to display the maps for your current position (with GPS enabled)?
- did you perchance activate "GPS ID bug fix" (must be off)?
- are the maps coordinates correct?
Regards
berni29 28.08.2008 11:16:52 UTC
Dell Axim x50 run.GPS
Hi There, I am running ver 1.2.7 (trial) and have copied some google maps across of my local area. I can see that it has loaded the maps and that none have failed, but they will not show under maps. Its just a blank screen with the path I have run overlaid on it. If I can get this workig I will buy the program.
Any ideas appreciated.
Berni
