GPS-Sport ForenRun.GPS Wishlist / IdeasSkip GPS detection on startup
shanrez 30.08.2008 20:47:04 UTC geändert am 30.08.2008 20:58:50 UTC
Thanks for the trick... That works indeed, and I'll do that for the time being, but that's not exactly what I need, because, now, the GPS doesn't connect anymore on startup...
What I would like is either an option to skip GPS detection on startup, or a configuration option to connect the GPS on startup, but without performing an auto-detection if the GPS is not found on the current configuration (I think that's why it takes so long, RUN.GPS is performing a test on all data rates...).
TauPas 30.08.2008 09:26:55 UTC
i had the same problem with the new Version, especially when no GPS device can be detected.
Look at Main-Menue/Konfiguration/GPS-Konfiguration
COM-Ports scan, switch off the button.
If you use a bluetooth-mouse, you can switch off bluetooth. It will help you, too.
Than rungps will start without gps.
Excuse my english
christian
shanrez 29.08.2008 14:37:09 UTC
GPS detection is taking a lot of time on startup of RUN.GPS, especially when no GPS device can be detected... This is annoying when simply willing to check log of older trainings... Wouldn't it be possible to add a "skip detection" button on startup screen for such cases?
Stéphane
