GPS-Sport ForenRun.GPS SoftwareNo GPS data logged
naddynoo 18.09.2008 12:16:45 UTC
That did the trick. Seems that RunGPS threads are still active if I have music running through my BT headphones. I used the lock button on RunGPS when cycling and it logged perfectly.
Thanks Tom.
naddynoo 11.09.2008 22:45:52 UTC
I use the standby button when I am running, and GPS data still gets logged. Could be that when I am running I also have MediaPlayer running music to my bluetooth headphones. Maybe that is keeping the device active? I don't use the headphones when cycling - for safety reasons....
I'll try a cycle without putting it in standby. Sounds like that could be the issue....
Tom 11.09.2008 22:03:25 UTC
> One thing I didn't do after I checked it was to turn off the display and keypad.
> I usually do that to stop any inadvertent key presses on my training. I wouldn't
> think that makes a difference as it doesn't affect logging when I run....
How do you turn off the display? It must be turned off using the little lock symbol.
If you press the "standby" button on the device, logging will stop because all threads
are frozen.
robert 11.09.2008 22:00:48 UTC
(discussed in parallel by email)
naddynoo 08.09.2008 16:48:41 UTC
No GPS data logged when cycling
I've been struggling with this for a while now with no progress. Everything works fine logging data for a run, but if I jump on my cycle I just don't seem to get any data logged, other than the time.
Is this a configuration issue? I am using a HTC Touch Pro with it's internal GPS.
