@CaptainCalamity: Hmmm seems like the device is not capable of getting a larger amount of contiguos memory. Run.GPS needs this amount of memory to create a large screen buffer in which the "scroll panels" are pre-rendered (e.g. the "Training Log").
This doesn't make sense, I have 42.98 MB of free Program memory on my Diamond, this is plenty and far more than most PDA's...so why the problem with the Diamond
Die Version 2.2.7 benötigt im Gegensatz zur 2.2.6 mehr freien Speicher - daher das "OutOfMemory"-Problem. Das Problem tritt insbesondere auf Geräten auf, deren Hauptspeicher bereits stark ausgelastet ist. Wir haben das Problem erkannt und eine neue Version 2.2.7 Build 1248 veröffentlicht (steht jetzt zum Download bereit), welche wieder mit weniger Speicher auskommt.
Release 2.2.7 requires more free RAM than 2.2.6 - this is why the "OutOfMemory" problem occurs. The problem is likely to occur especially on devices with many programs installed. We have now released a service update 2.2.7 Build 1248 (already on the server for download), which will operate with less memory, as in the 2.2.6.
13.10.2008 14:09:05 UTCgeändert am 13.10.2008 14:28:33 UTC
Have the same problem, had to reset my device twice at the weekend before Run.GPS would start, really annoying as I was running in a 10K cancer research race too...
I have a HTC Diamond also
PLEASE CAN YOU ADD A LINK TO DOWNLOAD THE 2.2.6 version as this worked perfectly...
UPDATE...found the 2.2.6 version, firstly uninstalled the latest version and installed 2.2.6....yet still I get the same error as below, but now even if I soft reset three times now, it wont run...HELP....
