GPS-Sport ForenRun.GPS SoftwareTraining Plan - issue using Firefox browser
tomapi69 31.03.2009 11:37:31 UTC
FF 3.0.8 and AdBlock Plus Addon
"My Training > List" item doesn't work: the trips are not located on the page correctly.
When I click into one running, then the page becomes very ugly and the map is incorrect: it shows the world.
gary_lee 06.11.2008 12:56:25 UTC
Thanks. Whatever the problem was - it is gone away. I've moved to Firefox almost exclusively as my browser now. I used it yesterday to enter a training plan in Run.GPS and Save / Cancel worked just fine. Not sure what I was seeing earlier - will keep an eye on it.
Great application.
robert 06.11.2008 10:15:26 UTC
Firefox should be fully supported. I've tried it on a FF 3.0.3 both on Windows and Linux and it worked correctly. I tested on a german Firefox with set to use english language. Do you also have the problem when you enter no parameters (only "duration")?
gary_lee 05.11.2008 17:42:18 UTC
When entering a new training plan entry to a day, it appears the Cancel / Save buttons do not work under the latest Firefox 3.0.3 browser - at least not for me. Trying the same under IE ver 7 seems to work just fine.
Is Firefox a supported browser for the Run.GPS server and apps?
