GPS-Sport ForenRun.GPS Softwarecolor bug?
Hietberg 10.11.2008 16:39:54 UTC
You are the best. I will try the beta, thanks
Tom 10.11.2008 12:40:43 UTC
Should be fixed in the 2.2.9. If you want you can already try an early beta: http://downloads.rungps.net/Setup_RunGPS_UV_EN_Beta229.exe
Hietberg 07.11.2008 17:28:58 UTC geändert am 07.11.2008 19:20:41 UTC
Hi Robert,
More specific. I tried a navigation route in a openstreetmap. This is with controls. I'm using a HTC Diamond. Because a lot in the maps are the same color green I can not see the route.
robert 07.11.2008 08:27:32 UTC
Do you want to change the recorded track or the navigation route? I tried it on the 2.2.8 and it worked on normal maps.
Maybe you are using a "Mini Map" (without controls) - on those it's not possible to change the track color (we will fix that in a service release soon).
Hietberg 06.11.2008 23:06:04 UTC
color of track
In version 2.2.8 I can not change the color of the track. It remains green? wathever color i select in settings? Now I can't see the track in green areas.
