GPS-Sport ForenRun.GPS Software2 bugs
robert 17.07.2007 15:34:44 UTC
Hi Frank
> 1. by closing the application, the question for saving unsaved data do not wait for > answer - reason for losing some sessions ;( - i wish there was a button to cancel
> closing
I think this should only happen if you close the application with an external task manager, right? If you close the application using the Quit Application menu item, it should wait for an answer of course.
> 2. editing the trainigs sessions on gps-sport.net is a little bit buggy, for
> example: changing the sport has no effect an the trainig analysis and will not
> change the burned calories
Yes, right. The reason for this is that the modules for calorie consumption calculation and the web server are on different server hardware at the moment ... so, it's a bit hairy to get those connected. But at least the rankings (except calories ranking) are recomputed :-)
