1. we will map the backlight function in the coming release 2.3.1
2. this works on all tested devices and in the emulator (check "use hardware keys" and also "alphanumeric keyboard")
3. if you activate voice output, interval changes are announced by speech
4. Run.GPS uses the HxM to detect cadence and heart rate, but not speed
Second post:
1. check "also lock keys" (General Settings) and "completely lock keys" (doesn't work on all devices though)
2. we haven't tested Run.GPS with "XBar" yet
<I see I'm one who tried to use your software on SP ;-) >
1. Lock function works - icon in comand bar was changed (I've tried to use Right SK, DownKey, 0, allthey are working), I believe this function locks touch screen, but on my SP this doesn't lock keyboard. ANy ideas?
2. (Not sure this is your bug but looks like that). I use XBar software - this is task manager for non-touch smartphones. When this software is running, all presses on keys are doubled. very oddly. all other applications work without any problem, only your one has this problem.
Any updates/plans to fix the bugs from previous post.
Hello,
[I wrote the similar letter to support but still no response there]
I have a plans to buy and use your software but after trial usage on my smartphone (non-touch) I found out some serious issues,
could you fix them or comment (maybe I was wrong with some ones)...
1. not all shortcuts on toolbar at the bottom are mapped on hardware keys - thus some of these very useful features are availble for owners of touch screens only (don't see the way to use it on SP), please bind they to hardware keys, especially - backlight.
2. TextBoxes doesn't work with hardware keyboard (usage of alphanumeric keyboard's activated). you can see this even in emulator.
3. There is not any notification about switching intervals, vibro or beep. to catch the intervals, I need to look at the screen during the workout permanently.
4. I've tried to use my Zephyr HxM but RunGPS doesn't show speed/distance values. I've double checked my unit on PC - yes, my HxM transfers a speed/distance data. thus, this is problem on RunGPS side. please fix it.
