GPS-Sport ForenRun.GPS SoftwareAltitude Reporting
mikael_axen 09.07.2009 14:07:56 UTC
Same problem with altitude report - SE Xperia
I have exactly the same problem, the first week or two I got altitude diagrams perfect, but suddenly the report says "no data". Very disturbing, anyone knows a solution? I can see altitude in the main window diagram, but not on a report. I use SE Xperia with the latest updates. Big Thanks!! /Mike
Clarus 11.04.2009 23:45:21 UTC
Any solution so far?
Running on an XDA Orbit
Config WM :
.Programme
GPS Programmanschluss: Com4
.Hardware
GPS Hardwareanschluss: (Keiner)
Baudrate 4800
.Zugriff
GPS Automatisch verwalten(Aktiviert)
Config Run.GPS:
Windows verwaltet(Aktiviert)
Beim Start verbindgen(Aktiviert)
<rest standard einstellungen>
Trainingsbericht PDA Version:
Geschwindigkeit/Höhe nach Zeit wird angezeigt
Höhe:
Keine Daten
Karte:
Karte wird richtig angezeigt
DOP alles angezeigt
There are not a lot of possibilities to change something.
Or does Altitude mean the Altitude from an external device. I hope not :-)
BrunoF 11.04.2009 14:08:52 UTC
Hello,
i do have the same problem.
This has nothing to do with the configuration, because i got the altitude information all the time except in the generated training report.
The altitude information are also available on the portal after upload and also on GPSies after upload. This seems like a bug in the program.
I do have the problem after i undated the program to the actual version.
I using RunGPS un an XDA Orbit
Greeting
Bruno
gmngueko 23.02.2009 12:51:26 UTC
COM port config
have you check this link: See http://www.rungps.net/wiki/DeviceConfigurationEN
it's critical to get correct altitude for htc touch diamond/touch pro, sony ericsson XPeria X1.
Pittyone 21.02.2009 18:21:46 UTC
Me too, i've same problem !!!!!
It's big problem for a program GPS !!!!
Somebody have a solution !!!
BYM 18.02.2009 10:02:44 UTC
Cheers,
I´ve been trying the program using my HTC Touch Diamond for the past 10 days. Excellent program!
I do have one problem though. The first few training reports I created contained altitude data (a picture), but the last reports suddenly states "No data". I do get the altitude information during the training - so I´m quite puzzled why it doesn´t show up in the report.
I´m not aware that I have changed any settings and I have already tried to reinstall the program.
Can anyone help?
Regards
BYM
