GPS-Sport ForenRun.GPS GeneralGPS not recording correct info
cybrslug 23.03.2009 22:50:15 UTC
Similar issue but possibly different
I just started using Run.GPS today. I did a 4.6 mile run using the application on a Samsung BlackJack II. I noticed when I uploaded the track to Run.GPS the map was completely wrong, it looked like I was zig-zagging all over the city. BUT!!!, if you look at the "Navigation" screen on my device, the track indicated on the OpenStreets.org map is exactly the route I ran.
What would cause the device navigation map to have the correct tracking data, but the upload to be extremely off??
gmngueko 23.02.2009 12:48:22 UTC
gps reception was not good
most likely the gps reception was not good, this is the fault of your gps chipset, the "rungps" software can't do much about it.
a trick is to set the DOP threshold in "rungps" to something around 7, so it won't record (in the gpx/kml export) point where the gps reception was not below that threshold.
it looks like you never got a good gps fix during your workout.
ilarman 22.02.2009 18:14:14 UTC
Used my Run GPS for the last 2 runs and when i upload it the info is all over the place. It records places that i have not run and adds incorrect route info.Why. I have a full licence for the software
