GPS-Sport ForenRun.GPS HardwareHTC TOUCH HD with RUNGPS
CaptainCalamity 07.10.2009 17:38:44 UTC
I have just changed from a HTC Diamond to a Touch HD and I find that RUNGPS works flawlessly, never get a problem with GPS, instant fix...actually think its better than the Diamond was.
I have WM6.5 running TF3D2.5 Leo Dutty's R5 rom
KuDabuTa 06.08.2009 06:31:54 UTC
GPS is known to have an error of about 30m (depending on the settings). Also - as GPS require line of sight for locking signals - they are known to be highly inaccurate in high rise areas.
I have perpetual problem trying to get a lock while mountain biking due to the trees! sigh.......
Merlin 26.07.2009 19:07:48 UTC
HTC Touch HD Button Lock
Hi
I had this problem with my touch HD. You can actually download an install a programme called AE buttons that will allow you to lock the volume and other buttons on your phone. I think it works for the home buttons as well. I use it and it works really well. Make sure you install it on your phone memory (rather than card)and when you use the phone for making calls it upsets the programme and you need to turn your phone off and on to make it work again. You can download it from:
http://ae.inc.ru/aebplus.php
Hope this helps.
rowi 25.07.2009 10:46:57 UTC geändert am 25.07.2009 10:48:50 UTC
Touch HD works fine with GPS!
I just use the standard settings for my HTC Touch HD and GPS. It works just fine if you prepare correctly ;).
At least 15 minutes before I go out jogging I start Run.GPS an let it soak up all the satellites (just let it be powered on with Run.GPS on my table). After this the route is quite good (just look at my routes).
I figured out that if I sometimes just go out and start jogging, the reception doesn't work all the time. I dont't get just one accurate (if one at all) position. Technically it seems to be more difficult for the device to get the first position while moving.
So just try to get a stable reception at home and look i this works.
best regards
Rolf
P.S.: Nevertheless I didn't figure out how to lock the whole screen including the buttons, so I have to be careful in handling the HTC while jogging.
ebola 01.06.2009 00:50:24 UTC
Hi , i just bought a HTC HD.
And i will try it soon with rungps i will tell you if mine works better or wurse.
My HTC diamond worked perfectly so.... we will see.
tarmac 25.03.2009 09:04:50 UTC
Hi Ian,
When zooming in a bit at your recordings, I don't think they are all that accurate to be honest.. for instance the tracks are crossing buildings on a few occasions. Don't tell us you're Spiderman ;) What GPS settings have you used?
lawboffin 25.03.2009 06:50:10 UTC
can i help anyone in here, i have a htc hd and it is amazingly accurate, ian
tarmac 23.03.2009 13:58:08 UTC
I've tried your exact settings, wobu2000, and this was the result:
http://gpsies.com/map.do?fileId=geslksialnjonqdx
So unfortunately it has not been an improvement, the track is really bad.. I don't really know what to try next :( I don't think that flashing radio ROM will do much, besides I'm hesistant to install any unofficial patches.
wobu2000 19.03.2009 23:36:26 UTC
Hello tarmac,
yes indeed, you have to use manually managed windows in RunGPS. The GPS menue in Windows mobile dont matters.
Then Your Touch HD normally will find up to 16 Satelites, the dilution will be 1.0 or sometimes less. Take a look at one of my last trainings for example.
If this dont work, you can flash your Radio-rom like I did. How to do, you will find on website of xda-developers.
greetings
tarmac 19.03.2009 16:35:49 UTC
Thanks for your suggestion, wobu2000. I'm going to try it, but to make sure I'm doing the right thing: do you mean changing these settings within RunGPS? That means in the GPS settings menu NOT ticking the "Windows managed" box and then manually selecting the values you mention?
Because in Windows you can't change the baudrate, it automatically sets it back to 4800.
Thanks again
