GPS-Sport ForenRun.GPS GeneralUSING RUN GPS WITH FRWD B-600
jeffn2001 30.04.2009 14:49:35 UTC
Also, I only use the lock button (on the screen) to turn off my screen, not the button on the phone (I have an HTC Mogul). I guess the physical button may turn off the BT(?). To turn the screen back on, I press the phone button and then press the unlock button on the screen.
jeffn2001 30.04.2009 14:36:34 UTC
It's happened to me several times when cycling, despite the phone and B600 being near to each other (but in opposite pockets). Ever since I placed the B600 and phone right next to each other (rubber band or same plastic bag), I haven't had a problem since.
Jeff
Tom 16.03.2009 10:30:30 UTC
We did not experience that problem yet.
- Maybe the HRM belt gets too dry?
- Try unchecking the .NET COM Port setting.
- If you use the device for GPS AND heart rate, it should only be configured as GPS device, NOT as heart rate monitor.
BR
suprodan 11.03.2009 15:35:17 UTC geändert am 11.03.2009 15:36:08 UTC
PAIRING BLUETOOTH WITH FRWD B-600
Hello,
I bought an FRWD B-600 device, and I started to use it.
I paired my Samsung Omnia with the FRWD device thru Bluetooth. Also started to work the Heart rate monitor perfectly.
I started exercising but noticed (after finished excercising) that the bluetooth devices (Omnia/Run Gps with the FRWD deviced) suddenly were unpaired after 6 minutes.
Both devices were on (with their blutooth active and visible). I just paired them again and it started working again.
Do you know what may have happened?
THe FRWD was not only on, but even with a good GPS signal.
Thanks in advance.
Best Regards,.
Marcelo
