GPS-Sport ForenRun.GPS HardwareHTC Touch HD Button Lock
Merlin 03.05.2009 12:59:33 UTC geändert am 03.05.2009 13:00:49 UTC
Hi
I had this problem with my touch HD. You can actually download an install a programme called AE buttons that will allow you to lock the volume and other buttons on your phone. I think it works for the home buttons as well. I use it and it works really well. Make sure you install it on your phone memory (rather than card)and when you use the phone for making calls it upsets the programme and you need to turn your phone off and on to make it work again. You can download it from:
http://ae.inc.ru/aebplus.php
Hope this helps.
Tom 16.03.2009 11:48:58 UTC
I think the best solution on the HD is to activate the function "When application is locked > Turn off screen completely" (General Settings). This will lock the keys when you press the Run.GPS lock symbol.
When you want to return to Run.GPS, just press the Power button.
Cheers
scott01236 16.03.2009 01:52:21 UTC
Is it possible to lock buttons or keep gps running whilst on standby
Hi, does anyone know if it is possible to lock the call, home, back, end call buttons on the Touch HD whilst running Run.GPS. As far as I can see I can lock run.gps but the buttons still work, leading to accidental calls, etc. If I put he phone on standby using the power button, my time is still recorded but the GPS shuts down and I lose tracking.
So I am thinking there are two potential solutions. One, to lock the buttons whilst leaving the phone on. Or two, switch the phone to standby, but enable the GPS. If I could do both that would be great as I tend to leave the phone/screen on when running so I can see time, distance, etc. but when walking I tend to put it to standby to save battery power.
Cheers
Scott
